Carb spring collar mystery?
    • 8223
    Folks,
    It is hard to imagine, but I think they were casting flaws.
    Using a cheap 10X eyeloupe directly upon my camera lens, I was able to capture two shots of an M344 that just arrived today. Unfortunately, it had previously been blasted, so I prepped it the rest of the way.
    Please note the resemblence to the dished M352 I posted earlier.
    The next two attachments are cropped from those photos.
    Note the grain in erosion1 appears to radiate from the bore.
    Under 16x with a stereoscope, no 'chemical' pitting is apparent.
    Although well scrubbed, erosion2 appears to show embedded micro glass beads?
    I didn't think they made them that small.
    The photo displays what could not be seen even with the stereoscope.
      • 8223
      Upon 32x inspection of the specks in my third photo above,
      the particles are not embedded, opaque, but spherical and reflective.
      I cannot identify them, but they survived hot soap and water, air pressure, and a cotton swab of carb cleaner to remove paint overspray!
      Damn tiny whatever they are.
        • 8223
        Another perspective...
        Folks,
        Here's an M75 H-D LLinkert that exhibits similar dished erosion beyond a machined counter bore surface. The large well bore doesn't seem to make a difference, although the circumference seems quite uniformly rounded.
        Inspite of the obvious wear mark, the spring collar retains its original nickel upon its bottom surface, making it a one-in-dozens, if not one-in-hundreds survivor.
        Unfortunately, I cannot capture its beauty just right in a .jpg.
        • Tommo
          • Sep 2001
          • 1318
          Cotton,
          I tried to send you a personal message but the system says your message box is full.
          Can you please send me your contact e-mail so I can contact you.
          Regards, Tommo.
          Peter Thomson, a.k.a. Tommo
          A.M.C.A. # 2777
            • 8223
            Tommo!
            I can be best reached at liberty@npoint.net
            Thanks!
