helicoil 18mm 1.5
  • helicoil 18mm 1.5
    doe's anyone have a supplier of an 18mm spark plug helicoil set? all the ones i have found have a high speed steel tap marked aluminum only, i don't think it would last long on 70 or 80 year old cast iron.
    thank you in advance dave 4746
