Yamabond for engine case
  • DANPATCH
    • Apr 2009
    • 313
    Is Yamabond the best gasket sealer for knuckle cases
    Dan!
    I used Yamabond 4 religiously in the late '80s.
    It turned out to have a life expectancy of about six years, which is great for a Yamaha.
    My preference is 3M #800 Industrial Adhesive, which is lited under an -80 H-D OEM number.
    It is ugly, though.
    • billpedalino
      • Mar 2005
      • 1096
      I've used Permatex No 2 (the liquid) between the motor cases for over 40 years. I've never, repeat, Never had a leak. and it comes off fairly easily with lacquer thinner or acetone, even when its been on for a long time.
      Bill Pedalino
      Huntington, New York
      AMCA 6755
        Bill!
        Gasoline will dissolve it too.
        So OHV H-D owners better have a perfect petcock!
        • bmh
          • Feb 2007
          • 901
          Hylomar works nice, If the flanges on the cases are in good shape. And gas won't eat it. I had some bad experiences with Yamabon, doesn't take much squeeze out to lock a motor stud in its hole real good.
          Brian Howard AMCA#5866
