Schebler carb question
  • Speedball
    • Oct 2010
    • 3
    Can anybody identify a Schebler DLX 7S. What was it used on? Thanks
  • 23JDCA 808
    • Jan 2007
    • 688
    This is a pretty good list of Schebler models, although I don't see a DLX-7s or DLX-75.
    Bill Gilbert in Oregon
      Speedball!
      If it happens to actually be a potmetal DLX-78, then it would be for a 1932 Indian 30/50 Scout Pony.
      Is it a Type A with the choke in the airhorn, or B or C?
      • Speedball
        • Oct 2010
        • 3
        Thanks for your responses. I have not been able to find the 7S on any list. It is stamped on the body of the carb above the cast in name. The choke butterfly is flush with the intake end and there seems to be no holes to attach an air cleaner. I will try to attach a picture.
          Speedball!
          It is indeed a Type A, although someone has crammed a chokeshaft through the two holes that would secure an airhorn.
          And I guess that's the HS needle in the LS hole.
          It is in very good condition!
          • Speedball
            • Oct 2010
            • 3
            Thanks Cotten, when and where would this carb. be used?
              Speedball!
              Your guess is as good as mine!
              .....Cotten
