Third gear end play. BT 4 speed
    Got a problem on main shaft third gear end play. The book calls for 0 to.017. I’ve been interchanging parts left and right to resolve this problem. I finely went into the stock room and I now have an Andrews main shaft, Andrews first and second cluster and Andrews third gear (this is all 59 and up). I give Andrews credit for making that cluster tight. I had to do the freezer/oven thing to get it on the shaft. I even put 15 tons on top of it on the press to make sure it was seated at the stops on the shaft and even with this, with a standard thrust washer (.062). I’ve got .035 end play on third. I’ve had that c clip out thirty times minimum. I even made a tool to retrieve the little sucker. Anyone else here had this problem. Bob L
    • 4791
    I'm sure that mainshaft and cluster were made with union labor. When they heard it was going to you they decided to f**k with you and make that small mind whir. Got to be it, part of the overall conspiracy theory running through your veins!
    Big brother is out to get you Bob!!
    Robbie
      What the f**k was that about?
      • Rooster
        • Mar 2009
        • 543
        That's what I was wondering too, Bob...!
        Robbie knows his stuff, the very best there is, but.... what's with the friggen 'tude, huh?
          • 4791
          Guess you came late to the party Rooster!
          Robbie
          • Rooster
            • Mar 2009
            • 543
            Robbie
            Yeah, I reckon I missed something along here somewhere......
            • knucklesbusted
              • Jan 2010
              • 3
              you can use late four speed thrust washers,they go up to the .070s in thickness,i have set up many early four speeds with later thrust washers.just went and looked the biggest i have is.078...
