Another speedo drive question
  • olddaze
    • Sep 2008
    • 65
    Built a Frankenstein transmission for my Shovelhead Trike project. Basically it's a `69 e-start case with a hand shift lid on it. I had planned on using the factory speedo drive that is on the Servi-car axle to drive my speedometer, so I didn't pay much attention to the drive in the transmission because I didn't plan on using it. Forgot about the fact that I am running the axle flipped upside down to drive off the left side (Oops). Axle drive now turns backwards.
    So, I need to fall back on the transmission gear to drive the speedo. Peeking down through the drive hole I count 5 teeth on the gear. Which drop-in drive unit do I need? 11, 13, or 23 tooth? And what ratio speedometer will I need to scrounge up?
    Member# 7397
  • bmh
    • Feb 2007
    • 901
    Are you sure you got 5? I thought the options were 4, 7, or 8. with two different 7 tooth gears.
    Brian Howard AMCA#5866
    • olddaze
      • Sep 2008
      • 65
      Sure looks like 5. But the trans is in the frame so it's hard to get a real good look at it. If those are my options, let's call it 4.
      What drop-in do I need? Resulting in what ratio speedometer?
      Member# 7397
      • bmh
        • Feb 2007
        • 901
        According to the chart Perry posted in another thread that would be a 13 tooth unit with a black gear. I think that's a 1:1 ratio speedo.
