Connecting Rod side play? '28 B Single
  • Lincoln
    • Apr 2009
    • 12
    Sorry for posting many questions but i haven't found a repair manual for this engine and i'm trying to rebuild her by hook or by crook. My question is how much side play should the connecting rod upper end have? Would i be safe in using the specs for an early 61" or 74" (.025" to 1/32")?
    Much Thanks,
  • Tommo
    • Sep 2001
    • 1321
    Lincoln
    The TOTAL piston to gudgeon pin bush clearance should be 3/32 give or take a few thou.
    Gudgeon pin bushes of varying lengths were available to achieve this.
    Some of the following may help also.
    Gudgeon pin in con rod (reamed) 1/2 thou
    Gudgeon pin in con rod (honed) 1 thou
    Big end roller clearance 1 thou
    Timing side mainshaft clearance in the bush 1 thou
    Drive side mainshaft roller bearing clearance 1 1/2 thou ( one and a half thou)
    Ignition advance on the piston 5/16 btdc
    Hope this helps.
    Peter Thomson, a.k.a. Tommo
    A.M.C.A. # 2777
