Porous engine cases
  • JPB
    • Nov 2001
    • 42
    Porous engine cases
    HI All - I've been told there is product out there on the market which is great for fixing porous engine cases on early antique/veteran motorcycles.
    I've been told it is a spray that is then oven cured.....
    Anyone know of it?
    thanks
    JP
    I have a few motorcycles, autocycles and bicycles
    I restore and recondition magnetos and generators - as I could never find anyone who did a good enough job.
  • rwm
    • Dec 2006
    • 1302
    rob ronky #10507
    www.diamondhorsevalley.com
    • JPB
      • Nov 2001
      • 42
      Cheers!
      Thanks - looks like it will do the job - do most people seal their inside cases?
      • bmh
        • Feb 2007
        • 901
        Can't say what others do, but I seal mine. H-D sealed them during original production at least till the early 70's so it's most likely a good idea.
        Brian Howard AMCA#5866
        • billpedalino
          • Mar 2005
          • 1096
          Harley used Gasoila for many years with good results. I've used it as well and like it, although I now prefer Glyptol (from Goodson).
          Bill Pedalino
          Huntington, New York
          AMCA 6755
            Beware that Gasoila has no resistance to modern fuels whatsoever.
            A leaky petcock on an OHV will curdle it into the oil upon sitting for any extended period of time.
            Sorry,
            It is not that there are not many fine products that have been used for generations,
            it is just that modern fuels are extremely digestive from additives designed for fuel injectors, etc., etc.
