Tranny main bearing.
    Can someone here give me a manufacture’s number for a early four speed tranny main bearing #9020. Found one in the shop and half the numbers worn off. Gonna try and get them though my local bearing shop. To say the least, old stock good ones. Bob L
    • 4791
    Bob,
    The number on one i just looked at is MRC 305 S F F. Hope that helps!
    Robbie
      Originally posted by Rub View Post
      Bob,
      Robbie
      Thank you! Not only does my local bearing supply have them. There $2.97 a piece less than Taiwan’s wholesale.
      • billpedalino
        • Mar 2005
        • 1096
        Are you guys talking about the large ball bearing on the main shaft on the right side? If so, that's a GREAT price !
        Bill Pedalino
        Huntington, New York
        AMCA 6755
          No, No Bill. They were $17.70 each not $2.97. I wish!
            Now that I got the bearings in hand. Here’s another question I’ve always wanted to ask. When ever I install one of these bearings I always removed the seal on the gear box side. Is there any reason to have ether seal in? I mean the kicker side has just as much oil as the gear side. What deference would it make? I figure the bearing would benefit from as much oil as possible. Input please! Bob
            • partshunt
              • 285
              This topic makes no sense to me. You say no not the right side bearing but the 9020 or MRC 305) is for the right side. Then, you say you paid $2.97 each for the roller or left side main drive gear bearings each? Hell, thats 44 X 9084 rollers at $ 2.97 each? Your talkin both sides mainshaft bearings er wut?...44 rollers at 2.97 is 120 odd bucks,,,ouch!! The 9020 r/side ball bearing at $17.50 is normal...Joe
              Joe AMCA# 3435
                Let me clear this up right now. What I stated was the bearings were $2.97 cheaper each at my bearing supply than one at my motorcycle parts wholesalers. As for my last post, I’m talking about the shields on each side of the bearing. I had no problem understanding it why did you?
                • knuckleheadtim
                  • Jan 2008
                  • 141
                  Robert:
                  I always leave the shields in place to block out any debris that may find its way into the bearing. It won't lack lubrication and the oil around the bearing will keep it cool. If you get the SS bearing instead of the FF, it has metal shields, but they are just shields and don't seal the lube in or out. Either one works fine.
                  Tim
                    • 4791
                    partshunt,
                    Go back and re-read it. You seem to have missed the whole thing.
                    Robbie
                    • partshunt
                      • 285
                      Well , if you look back, what threw me off was when Bill asked if he was refering to the right side ball bearing , the authers answer was no and also no to the price. two no's for each question? I do know I have a hell of a time understanding credit card agreements, thats a fact, this one come close to it the way I saw it.......Joe
                      Joe AMCA# 3435
