pushrod guide removal
  • cscott
    • Oct 2002
    • 451
    looking for advice on the best way to remove the pushrod guides in my 1932 indian chief.....thanks chris
  • indianut
    • Feb 2005
    • 308
    I made a little jack to remove them.Just use allen screws and put little pads on the bottom of them so you don't mar the case. Here is a Crude drawing!
    http://laughingindian.com/
    A.M.C.A. Member Since 1986
    • cscott
      • Oct 2002
      • 451
      thats looks like the right tool....do you find it necessary to heat the case ...use penetrating oil or anything like that ...thanks chris
      • indianut
        • Feb 2005
        • 308
        Nope....just crank it out, slowly and carefully!
        • Kiwi Mike
          • Jan 2007
          • 15
          push rod guide removal
          Always preheat the case when fitting and removing items from alum including the pushrod guides as it is easy to broach (tear) material during removal or installation. 250 deg F is fine. I made up a slide hammer type tool that extracts to push rod guides from the case. When done, allow case to cool down very slowly. An oven is best. Do likewise after reinstalling. Mike Kiwi Tomas, Kiwi Indian Motorcycle Co
          Mike "Kiwi" Tomas
          www.KiwiIndian.com
            Hammers are for Harleys.
            • Kiwi Mike
              • Jan 2007
              • 15
              Being a bit harsh on the Harley guys aren't you. Their parts need loving too.
              Mike "Kiwi" Tomas
              www.KiwiIndian.com
                • Feb 2003
                • 5353
                It's always nice to have the right tool. There are times though that I find a hammer satisfying..... even if it's only to throw across the shop......
                Cory Othen
                Membership#10953
                  Harleys can handle a hammering.
                    • Feb 2003
                    • 5353
                    It looks like they used hammers on Excelsiors too.........
                    Cory Othen
                    Membership#10953
                    • Ohio-Rider
                      Supporting Member
                      • 852
                      If you can’t fix it with a hammer, then it must be an electrical problem.
                      Steve
                      AMCA #7300
