going 40 over on my 50 pan and just wondering what would the best piston be. I've been looking at KB cast what the opinion of the masters?
best pistons
Something to keep in mind, the KB pistons for pre Evo models can be up to 100 grams lighter than oem or oriental replacements. This will significantly change your balance factor. Not a big deal if you are doing the whole motor and you balance with the KB piston weights.Kyle Oanes AMCA # 3046
Originally posted by Glenn View Postthanks Kyle
anyone have the V Twin part number for the 40 over KB's cast
http://www.vtwinmfg.com/Catalog1/VTwinCatalogIndex1.htmBe sure to visit;
As far as the weight, I have put brass into a wristpin to compensate for light pistons with no problemsl noticed.
piston weight
Originally posted by indianut View PostAs far as the weight, I have put brass into a wristpin to compensate for light pistons with no problemsl noticed.
Am I missing something?George Tinkham
Springfield, IL
www.virmc.com
AMCA # 1494
1941 Indian 841
1948 Indian Chief
1956 H-D KHK
1960 CH
1964 BMW R69S
1984 Moto Guzzi V65Sp
I had to add heavy metal to the flywheels in my '69FL. I'd rather add a little reciprocating weight to the wrist pin than drill out, or add metal to flywheels. All of this changes if you're building a stroker, but stock motors can tolerate moderate adjustments.Eric Smith
I'm building a '47 FL knuckle with stock bore A.M. Barrels. Neither V twin nor J&P designate their pistons as "knuckle specific" for a 74" bore. I'm told that the pistons for Knucks, Pans and early Shovels are all the same in height from wrist pin to crown? Comments? What brand & forged or cast pistons would you knowledgable guys suggest? Flat-Happy said above that forged pistons were giving him a "chirp". Was this on a flatty or an OHV? Does it matter? Thanks for your expertise.
