Problem with Piston Pin Keepers
  • dommi7
    • Jul 2001
    • 109
    I need a little advice here- I'm rebuilding a 41EL. My pistons came without pin keepers. I bought a bunch of piston pin keepers 22581-32 from Dixie. These are the L cross section type. I have the proper tool 12052-32 to install them. But these keepers shatter or break every time I try to install them. I can't even slide them down the tool. Has anyone had a similar experience?
    I guess I'll try another vendor - the ones I have are very stiff and brittle. Can anyone recomend a reliable source?
    I measure the pin OD at ~0.793" and the keeper groove at 0.750". Can anyone confirm I'm using the correct part?
    Thanks in advance,
    Ralph
    Ralph
  • flat-happy
    • May 2009
    • 543
    i've never broken one and it sounds like you have the right stuff but i cant confirm the dimensions tonight. i always put the opening in the snap ring at 12:00 or 6:00 because they will jump off or break if you put the opening at 3:00 or 9:00 sometimes but not all the time
      I have broken an NOS OEM keeper upon installation, but never a modern generic repop!
      I attributed it to crystallization with age.
      • dommi7
        • Jul 2001
        • 109
        I picked up another set this morning from Lee's Speed Shop (Thanks Lee!). Hopefully tonight I can get them installed. (Cross your fingers, knock on wood)
        Ralph
        • dommi7
          • Jul 2001
          • 109
          I installed my new keepers last night - this set was allegedly from Eastern. No problem, everything went together well, pistons and cylinders are installed.
          Ralph
