Panhead valve oilers.
    Panhead intake valve oilers part 18100-49 and 18102-49. Since these sport a 49 at the end where they used on the 48 engine? Bob
  • motorhead1
    • Dec 2006
    • 171
    The parts manual states 49-65. They were not used until 1949 but that does not mean you can't use them on a '48. Did you ever find that XL clutch hub Bob?
    Ride 'em. Don't hide 'em.
    Dan #6938 FUBO
      Dan that wasn't me. I think it was Bill Pedalino with the hub. Thanks and I'm going to run the oilers on the 48.
      • bmh
        • Feb 2007
        • 901
        Robert, If your looking to do your 48 motor just like the factory did inside and out you should read Shop Dopes # 262, 263, 269, 278 & 278A. All of witch can be found in shope dope vol III published by Antique Cycle Supply. Their 48-57 service manual contains alot of the same info plus info on proper set up of the mentioned valve oilers. I remember reading somewhere that valve oilers that are to be re-used should not be cleaned as this would lead to over oiling. Don't know how true that is though.
        Brian Howard AMCA#5866
