In an attempt to increase oil flow to my '74' Period Drag Bike Sportsters 'Top End', I am considering increasing the I.D. of the upper oiling lines, top/lower fittings I.D. holes and crankcase/rocker box fitting oil passage holes inclusive. By doing this will I increase the flow but at the risk of lowering the pressure to the rocker arms? Or will both pressure and flow increase? Also is there any way to effectively increase pressure from the stock pump? I run straight 50/60 WT Castrol Motorcycle Racing oils thru a remote spin on type 'Fram' filter. Any thoughts?....
..Hrdly-Dangrs
..Hrdly-Dangrs
..Hrdly-Dangrs
...Hrdly-Dangrs
