one hole vs 3 hole crankpin
  • one hole vs 3 hole crankpin
    (For HD OHV) I see several vendors offer crank pins in 3 hole and 1 hole versions. Which is preferred and why?
    Are there specific configurations that require one or the other?
    (For the sake of discussion, how about the years 1941, 1951, 1969?)
    Ralph
    Ralph, I like the two hole pins for even oiling and no holes in the bearing path.
    Kyle Oanes AMCA # 3046
      I,m a two hole guy myself, but they seem to have gotten hard to find as years went past. I'll run a single hole before a three, there is a thing such as over oiling and if it's fed with a side oiling pinion shaft the three can actually under oil at idle and over oil at RPM.
      Brian Howard AMCA#5866
        Thanks guys.
        Ralph
