Cylinder base studs
  • DanM
    • May 2005
    • 465
    Cylinder base studs
    Hi- Are the HD cylinder base studs made as an interference fit to the cases?
    Is it ok to use a std tap to clean up the cases? It appears that the threads of the stud is where the interference fit comes from, at least my tap wouldn't go more than 1/2 turn.
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
  • vph-d
    • 1088
    It is my understanding that the base studs were an interference fit.
    VPH-D
