WLA - High Compression Heads Horsepower
  • RvP
    • Aug 2005
    • 105
    While I am sorting out my cylinder problems I was wondering about putting on the high compression heads. My WLA has the #5 heads and depending where you read, the #5 heads are good for 22 horsepower. What is the expected horsepower with the high compression heads? Any draw backs to using them such as head/valve clearance problems? Overheating?
