panhead cam covers
  • bmh
    • Feb 2007
    • 901
    panhead cam covers
    I waswondering if anyone can tell me if the breather pipe in a panhead cam cover is cast pressed in as it would seem to be? If so what is the best aproach at removal? Also any tips for reinstall? I have a cover I would like to use very much, but the gasket surface will need trued up in order to do so. Figuired it was best to seek some advice before I went and made matters worse all on my own.
    Brian
    Brian Howard AMCA#5866
    • 2017
    It is pressed in and comes out easily with a plier or something that grips good without grrrring.
    Jerry
    • bmh
      • Feb 2007
      • 901
      Thanks. That's what I thought , just didn't wnat to take a chance on messing up a cover to find out.
      Brian
