65 FLH Cam Cover Welch Plug Leak
  • Garym
    • Nov 2004
    • 98
    On the 63-65 Fl models, that have the outside oilers for the cylinder heads, there is a hollow screw, at the top of the cam cover, that directs the oil to the cyclinder head oilers. Directly above that is an oil passage that has a welch plug in it. My problem is that oil is leaking from the welch plug, and I prefer, at this time not to remove the cover, for repairs. The welch plug is 0.25" in diameter. It looks like, if I remove the hollow screw, that I may be able to punch the welch plug into the area normally occupied by the screw, and retrieve it, then replace it with a new one.
    Has anyone had this leak, and come up with a method to repair it, with removing the cover?
    Anyone have a good source for welch plugs?
    Gary
    Gary!
    Welch plugs seat onto a shoulder; You would damage it to push the plug inward, leaving a poor surface for the new plug.
    Perforate the plug with a small punch and use a sheetmetal screw to pull it outward.
    Plugs are probably a universal auto product, but a proper size punch should make one easily. The original sealer was red, like Gasoila or Glyptal.
    Good luck,
    • Garym
      • Nov 2004
      • 98
      Thanks Cotten. I was unaware of the plug sitting on a shoulder. It pays to ask!
      Gary
      • P LaLonde
        • Jun 2004
        • 12
        Gary, hear is another idea, after cleaning the area with Brake Cleaner, an blow drying it ,try some FINGER NAIL POLISH of that color. let it dry ,an refire your bike. I have used it before on automotive carbs, an other Small leaks.
        Paul
        • bmh
          • Feb 2007
          • 901
          Loctite has a cappilary action thread lock and sealer,It's designed for use on things that are already assembled. I think the number is 209, but I would have to check to be sure.
          Brian
          Brian Howard AMCA#5866
          • Garym
            • Nov 2004
            • 98
            Thanks Everyone,
            I tried the thread-locker(loctite green), and that did not work. I next tried the nail polish(I used clear) and it worked fine. It was a small leak, about 3 drops of oil, in 40 miles of operation.
            Thanks again, for the tip!
            Gary
            • Garym
              • Nov 2004
              • 98
              Well, the nail polish lasted about 100 miles. What's next? Maybe J-B Weld.
              Gary
              • bmh
                • Feb 2007
                • 901
                How are you cleaning it before you apply anything? Nothing is going to stick if there's still oil in the nooks and crannies.
                Brian
                • Garym
                  • Nov 2004
                  • 98
                  Hi Brian,
                  I used a wax and grease remover with a Q-Tip, and followed with compressed air.
                  Gary
                  • mmoore
                    • 193
                    you probaly wont find a good sealer unless you use something like (shudder) jb weld which I would not do. but what cotten said was how we used to fix them at the dealership (years ago) using a sharp punch instead of drilling keeps shavings out of your oil. it does work and will probaly be faster than waiting to let the jb dry. I would use locktite on the new plug to help it seal. I used a slide hammer with a tip that would hold a screw I bought (cheap) years ago it beats pulling with pliers. it was made to pull dents out of fenders. give me a good measurement on the diameter of the hole as I still have some laying around and I will see if I have one.
                    3899
                    • Garym
                      • Nov 2004
                      • 98
                      Thanks. It's 0.25". The original welch plug is recessed quit a bit, so it looks like one could almost press another on top, depending on the thickness of the plug.
                      Gary
                      • Garym
                        • Nov 2004
                        • 98
                        This is like beating a dead horse, but what ultimately worked best for me, was super glue. It's been about 500 miles, since the application.
                        Gary
                        • Garym
                          • Nov 2004
                          • 98
                          I found that super glue worked the best. I have about 500 miles, since my temporary fix, and no leaks.
                          Gary
                          • Garym
                            • Nov 2004
                            • 98
                            Just an update. I found that "Super Glue" worked best. It's been about 800 miles, and no leaks.
                            Gary
