Carb ?
  • Carb ?
    I am rebuilding a m-51 carb, There is a small idle plug that I can not get out and I was wondering if it needs to be taken out or can I leave it alone, Thanks for any help
    gpetty!
    If you are rebuilding the carb for yourself and not a client, AND you do not use vibratory or blasting media...
    Then it *probably* will not present a concern.
    Shortcuts only bite professionals, as amateurs only answer to themselves.
      My thinking exactly
