65 FLH Flywheel Timing Marks
  • Garym
    Does anyone have knowledge of the timing marks on the flywheel? I have two marks for the front cylinder: two vertical lines followed by one dot, and one mark for the rear cylinder: one vertical line. Can one of the front cylinder marks be used to statically set the timing, with a indicator lamp, for the retarded setting?
    Gary
