While cleaning the starter motor housing, I noticed a build-up of grease. I assume this is the original grease for the armature shaft gear, and larger gear that drives the bendix assembly. No mention of greasing these gears, or what kind of grease to use in the manual.
Also, I noticed white grease inside the starter solenoid, for the solenoid armature.
Does anyone know of the correct lube for these parts?
Gary
Gary
