Panhead Left Case Repair
  • billpedalino
    • Mar 2005
    • 1096
    Over the years I've seen advertisements for shops that specialize in substantial motor case repair. Unfortunately, I haven't seen any such advertisements for awhile.
    I have a 1953 FLE that needs the left side cast-in roller race insert bored, sleeved and honed to stock I.D. The existing race has spun and damaged the cast-in steel insert, so I would send both cases to the machine shop so they could indicate the correct bore location of the left race using the pinion race location. Also, my preference would be to slightly chamfer the O.D. of the sleeve and braze a couple of small locations with a small amount of brass to ensure against future spinning..
    I was in this business in my youth and I know how sensitive and sometimes fragile these sand castings are to this kind of work, so I'm really interested in a shop who knows Harley cases very well. Can anyone recommend such a company?
    Bill Pedalino
    Bill Pedalino
    Huntington, New York
    AMCA 6755
  • dukekleman
    • Jul 2022
    • 597
    Bill,
    Do you have an idea of how much damage has occurred to the cast in insert?
    Would the cast in insert be able to be honed .010", .020", .030" to be cleaned up for the proper interference fit of a new oversized case race?
    They make over sized case races and I've done it before is why I ask...
    Duke Kleman
    • knucklehead 61
      • Sep 2016
      • 353
      Originally posted by duffeycycles
      I've never dealt with him but maybe Accurate Engineering
      Berry retired & is only working on his personal projects now.
        • 4791
        A replacement race could be hard chromed and ground to any size you like requiring just minimal removal of case material.
        • billpedalino
          • Mar 2005
          • 1096
          Yes that's a good point and an efficient fix. But the I.D. of the hole is too far worn - I would probably need about 0.020 plating buildup..
          Bill Pedalino
          AMCA 6755
            • 2025
            Bill
            V-Twin offers an Eastern made left case race at +.040. I would not dream of sleeving the hole if it would clean up at +.040. V-Twin # .10-0951
            This is their description:
            Machined and ground to factory specifications.
            *NOTE: Outside is .040" oversize, machine case to accept larger case bushings. Barrel spigot holes must be machined to match after installation of the left side case.
            EL 1940-1952
            FL 1941-1954
            • billpedalino
              • Mar 2005
              • 1096
              Originally posted by Jerry Wieland View Post
              Bill
              EL 1940-1952
              FL 1941-1954
              Jerry,
              Yes, I was informed by Dukeklman that Eastern now makes larger oversize's. When I was with them they only went to +0.0010" or so. Thank you both for pointing that out. I'll have to see how fat the hole has been previously machined to. Hopefully it will clean out at less that +0.040".
              Bill Pedalino
              AMCA 6755
                • 6041
                I may have the same issue with my '48FL left case, Bill. Curious to hear how you resolved your motor case problem?
