Linkert throttle disk questions
  • marksg
    • Mar 2023
    • 128
    IMG_8972.jpeg I had a good elementary understanding of Linkert Carbs until my newest issue.
    new restoration with a m36 on a 1949 FL.
    hard time getting a good idle and a huge flat spot when throttling up for speed. Great full throttle power.
    i have had the carb apart a few times and now for another deeper look.
    i have swedged the Venturi to get a better fit and now have a good snug fit at the manifold end.
    next issue is i think the throttle disk fit.
    appears to be no wear groove from the disk but plenty of daylight mostly top and bottom.
    i believe it should have a #12 disk but it currently has a x9
    Am I correct the the disk fit is an issue?
    measuring the disk it seems the wear is mostly top to bottom with little wear side to side.
    from what I can see online it appears the disk is much smaller than new.
    looks like I should not need an oversized disk?
    it looks like ther is about .0010 clearance disk to body.
    This gallery has 5 photos.
    You might notice, Mark,
    The discs are oval, not round, as they must close upon a round bore at an angle (or else they could just spin. (The angles provided different duty characteristics, naturally.)
    Thus they must be measured at the shaft axis center, in line with the screw holes, as that should closely approach the carb's bore diameter. (A disc cut to the bore diameter, at proper angle, produces the rest of the oval.)
    And yes, that's excessive daylight; Its a real trick to get the screws in from the front of the carb like that, unless its just in backwards and that's causing most of the daylight. Please remove it and inspect the bore a for a wear groove anyway Then reinstall the disc with the throttle lever opened fully to its stop.
    The screws and locks can then be easily installed where they will seat upon the flats machined upon the shaft.
    It takes great patience to center a worn disc to a worn bore to where it best fills the gap, if possible, before tightening.
    • marksg
      • Mar 2023
      • 128
      Thanks Tom,
      The pictures were taken with the screws out. However the gap is the same with them in.
      The picture I attached with the screws in alignment show a disk diameter of 1.558". I was wondering if that is standard size. The bore size appears to be about 1.568".
      I am not sure if the bore is worn and I need an oversized disk or if the disk is worn and I just need the correct #12 disk.
      Here is a picture if the bore and there is no wear groove. I can run a fingernail over the wear area and feel no groove.
      Also is part of the problem that it has a 9X rather than the correct #12 disk?
        The original bore was 1.5625", Mark,
        So I would arbitrarily grind the flange, torqueplate and pass a hone through it for certainty, cut an oversized 12º disk, and then swage and fit the venturi accordingly.
        • dukekleman
          • Jul 2022
          • 597
          Mark,
          I agree with Cotten. You have many issues causing your problems. Correcting all of them properly will remedy the calibration issues your experiencing.
          Be sure to look over your main nozzle for correctness. It may have been changed over the years or altered in the many ways I've seen in the past.
          Lastly verify engine integrity, this includes cylinder compression, cylinder leak and valve clearance adjustment. If these items listed are not correct, the calibration will not work as intended.
          Hope this helps,
          Duke Kleman
          • marksg
            • Mar 2023
            • 128
            Thanks again Tom,
            So when I go that route I will need to have about .002" - .003" disk to bore clearance top to bottom?
            The only oversize #12 disk I see are .025" over. That seems like a lot to hone?
            • marksg
              • Mar 2023
              • 128
              Thanks Duke,
              I have been through the bike a half dozen times trying to get it perfect.
              It is ridable but not what I want at idle and I hate the hesitation when I roll the throttle.
              The main nozzle looks unaltered and it runs great in the mid-upper range. Nozzle also appears just like the one i found online. 1258-40
                Originally posted by marksg View Post
                Thanks again Tom,
                Honing .025" oversize could blow through the idle bleeds, Mark...
                And rob the carb of more lifetimes even if it didn't; Most obviously worn carbs clean up under seven over. You only want to remove wear and distortions...
                Once you know your finished bore size, perhaps the commercial oversize disc could then be cut down to just under it, on a 12º mandrel:
                I aimed for a half-thou less than the bore, as when cut exact, the carb had to be re-torqued for the disc to be assembled!
                .....Cotten
                • marksg
                  • Mar 2023
                  • 128
                  Ah that makes sense. Thanks.
                  Pretty trick mandrels.
                    ...i have swedged the Venturi to get a better fit and now have a good snug fit at the manifold end.
                    You make that sound so easy, Mark!
                    I always had to swage both ends at least ten or fifteen thou oversize, and then lathe-cut to a light press-fit; Vibration from one bouncing around not only wears the nozzle spigot, defeating the nozzle's "accelerator sump" function,
                    But I even encountered grooves from the venturi into the bore itself, albeit a much older DLX:
                    (The mystery is how they could run so incredibly long under such conditions.)
                    ZAMAC is such a bizarre "super-cooled" liquid that a swaged venturi will shrink to a slip-fit in about a year, but stays far more concentric than a seventy-five year old one.
                    • marksg
                      • Mar 2023
                      • 128
                      Thank you Tom,
                      Luckily mine is no where close to the issues I see in the photos you are posting. However it shows me what I should be looking for.
                      I ran the carb flange over some 220 grit on a granite slab last night and it hit the full surface in two strokes.
                      I am only a couple of years into the vintage stuff and I really appreciate the knowledge provided by many on this forum. Many of us will be timing out so sharing this knowledge is important.
                      Much appreciated.
                        The extreme examples, Mark,
                        Just show why you want to avoid a rattling venturi.
                        Your bore is apparently oversized five and a half thou or so, plus venturies commonly shrink a few more, divided by two for radius, and you could have four thou of slop at the front, even if the rear is pinched.
                        Please remember its not just the engine vibrations that make them shake, but the intense vacuum pulses (and hopefully minimal reversions).
                        PS: Just for extremes, here's one that begs explanation.
                        M74 series are not known for their leadpest.
                        • marksg
                          • Mar 2023
                          • 128
                          Follow up. OMG
                          Incredible change in the performance of the bike.
                          I bought a .025" oversize #12 throttle door and size it down about .017" to get a good fit in my M36.
                          The bike will now start first kick and idle down to about 400 rpm. (that is a guess and no I don't leave it that low) Idle screw now set to about 1.5 turns rather than the 8 turns it was taking.
                          I really appreciate all the wisdom on this forum and the ability for some to share that knowledge.
                          My favorite part of this hobby is the learning and this was a big one for me.
                          Now I have three more bike with linkerts that need looking after.
                          • dukekleman
                            • Jul 2022
                            • 597
                            Mark,
                            I'm happy to hear that you are up and running!
                            Correcting problematic issues from years of service is important so that these motorcycles can be ridden and enjoyed as they deserve.
                            Duke Kleman
