Can someone educate me on why a BT OHV (maybe BT SV too?) has the crankpin key on the right flywheel and a 45" SV has the crankpin key on the left flywheel? I would think the right would make more sense to ensue line up of the oil feed hole. I know the wheel shouldn't be rotated enough to matter, just curious as to why the difference.
And a follow up question. It seems like HD OEM nut to shaft fits (concerning flywheels) are very tight, (not a hand assembly). I compare a new 'Jim's' shaft and a new Colony nut and the assembly is a fit like (me being a machinist) would fabricate. Sometimes the Colony nuts are too tight on an OEM shaft, same as oem nut to shaft fit. Is the opinion that HD made their shaft threads on the larger side of the pitch diameter for a very tight fit or this just happened through production tolerances? I just hate threading a nut on with a wrench from the get go. Opinions?
Thanks.
Thanks.
) HD mechanic friends of mine about the nut to shaft fit issue. They both said they encountered this problem all the time and had a bin full of nuts and match fit until the thread is good tight hand fit-not loose, but not where you need a wrench to actually apply heavy pressure to get the nut on. You may actually get pre torque before you get the nut seated. They both have had to lap the nuts to the threads and both feel the copper was only for heat treat purposes. I actually feel that if the threads are lapped for a good tight fit you will have much better contact with very minimal 'air gap' contact surfaces. I've decided to fit tight but without forcing the nut on the copper coated soft threads which could cause a galling. I appreciate the conversation and input from everyone. This is alot more fun than welding the crank pins to flywheels like modern HD's do! IMO
