45 transmission problem
  • schmillen
    • Aug 2022
    • 8
    I have a 1942 Harley 45 that will not shift into second gear. First and third work fine. Any ideas?
  • otis71
    • Jul 2015
    • 597
    Before pulling the transmission try adjusting shift linkage. Sometimes the least little bit out can keep it from going or staying in gear.
    • schmillen
      • Aug 2022
      • 8
      Thank you, sir. I’ll do that.
        • 2044
        45" 2nd is the one that is tricky for many to setup properly.
        • schmillen
          • Aug 2022
          • 8
          Thanks for your response. I’ll try adjusting the shift linkage to see if that helps.
          • Architect
            • Dec 2014
            • 283
            If the pivot bolt at the gas tank holding the shifter gets loose, and they do, all sorts of problems arise. Checking your linkage first is good advice.
            • schmillen
              • Aug 2022
              • 8
              Thank you for your response. I will check the shifter linkage first.
