1940's Indian 4 speed/reverse transmission
  • mradon2020
    • Jan 2020
    • 14
    Does anyone have diagrams for this transmission? I have a full break down of the parts. Any shop manuals with assembly instructions? I believe I have all the parts to assemble a reverse transmission. Any help is appreciated.
  • ryan
    • Mar 2017
    • 610
    So do you have the parts to build a 4 speed or a 3 speed with reverse? Or did Indian make a 4/R trans?
    • mradon2020
      • Jan 2020
      • 14
      I have many of the parts to build a 3 speed with reverse.I have the case and tower and all but one gear and the shaft that that it turns on. My only parts reference is a 1941 Indian manual that shows the part numbers for both a 4 speed and 3 speed with reverse but no diagrams for the reverse. A diagram for the 3 speed /reverse trans would be helpful. I talked to Mike at KIWI Indian he said he has never seen any diagram. If I can't get any information it might be time to sell what I have if someone who can use it.
      • bstevens479
        • Jun 2011
        • 109
        My understanding was those transmissions were for ridged frames only 1935-1939
        • elmo
          • Dec 2010
          • 53
          I have all the gears for a spring frame chief 4 speed for sale pm me if interested I also have the drive gear for the ridged frame needs repair thanks Elmo
          • mradon2020
            • Jan 2020
            • 14
            My parts information is in a 1941 manual. It shows parts for both types of transmissions. It looks like they may have been for both a ridge or spring frame model. I believe there are different length
            sprocket drivers.
              • 959
              And mainshafts to match.
