Early 45 3 speed transmission help
  • montij
    • Jul 2022
    • 138
    I’m looking for a diagram of parts for my 1929 model B single transmission. I’m planning on swapping over to the earlier case pictured in order to clean up and repair the current case. I have purchased the parts that were obviously missing but I’m unsure if I’ve now got the complete package. For example I’m unsure how this long clutch actuating rod I just received operates as I’ve yet to tear down the transmission.
    any information appreciated
    This gallery has 1 photos.
    Justin Monti
    AMCA #43973
    • 2044
    Clutch release arm with lever goes into sprocket cover.
    3 piece throwout brng in sprocket cover large hole..actuated by arm/lever to brng to rod.
    There are many different lengths of rods for different years & models.
    Do you have Johnny Sells book?
    • RCamp
      • Jul 2012
      • 99
      As duffeycycles stated, get Johnny Sells book vintagemotorcycleworks.com. It contains a parts break down, disassembly and assembly instructions,
      plus photos of all the correct parts. Over the years, three different lengths of the push rod were used. If you have the correct clutch ( I can't tell from your photo ),
      your push rod needs to be 8 3/8" long.
      You clutch release arm is correct for 1929. Your sprocket cover should have a 384-28 casting no. inside if it is the correct one.
      Even if this is the correct sprocket cover, I wouldn't use it with the missing 4th mounting point.
      • montij
        • Jul 2022
        • 138
        I do not have his book. I can’t seem to get the rod to go in more than 2 inches perhaps something Is broken off inside
        Justin Monti
        AMCA #43973
        • montij
          • Jul 2022
          • 138
          I also received this clutch arm which is too short at the base to be used with this sprocket cover. I will order this book today.
          This gallery has 2 photos.
          Justin Monti
          AMCA #43973
