Valve guides, guide fits, and why it matters: A general overview
  • chuckthebeatertruck
    • Jun 2018
    • 691
    For several years, I moderated a private motorcycle forum dedicated to helping amateur mechanics better understand how/why professional mechanics approach work in different ways. Amongst the most misunderstood aspect of old motorcycle work are valve guides.
    Much of this misunderstanding comes from old literature as well as Uncle Bob’s grey beard advice to “lap ‘em in.” In most cases, this information reflects a difference between making a motor run and making a motor last. Recently, I’ve read a few posts here on the AMCA forum which perpetuate some of this misunderstanding. The purpose of this thread is to give a 10,000 foot overview of guide replacement to help dispel some of the confusion. It is not a primer on how to replace guides, but rather an overview of general proceedures.
    So, what’s the big deal?
    Most people believe that valves shed heat through the seat. They do – but what most fail to realize is that the efficiency of that transfer is directly related to seat and guide condition. If the seat is not concentric to the guide of if the clearance from stem to guide is excessive – the valve will perish in an unreasonable amount of time. Similarly, if the guide is not a good fit in the bore it develops hot spots. If these hot spots coincide with thrust areas the result is rapid wear and often a bluing of the valve stem. The bluing is an indicator of the valve being overheated. Overheat a stem often enough and very bad things happen.
    The biggest mistake is using any type of goop to try to make a guide fit. Whether loctite or scotch weld, goop should never be used to make up for a crappy guide to bore fit. As to why – the answer is super simple – the guide relies on its fit in the bore to transfer heat. Loctite is a poly and insulates. Scotch weld does transfer heat but has no holding ability. In short – you’re either insulating or wasting time, but you aren’t actually repairing anything if you rely on goop to deal with hogged out or buggered up valve guide bores. An equally poor idea is knurling guides or guide bores to make them fit. Again, "making" something fit by stretching and puckering the metal isn't the best idea here. The parts were precision machined for a reason.
    Guide material also makes a difference. In addition to there being several types of “cast iron” there also are several types of bronze used for guides. All of these materials work – and it is almost always the best idea to fit guides to original pattern. And, unless you can find the exact same operating parameters as your machine -- don't be tempted to transfer knowledge from another make/model. Just because soft bronze guides and stainless valves at .001 work in one motor does not mean they will work well in another. If you really don't know -- just ask. The AMCA has a lot of knowledge.
    Where no guides are available, it is advisable to make them from 40,000 – 60,000 psi grey cast iron. It is NOT difficult to make guides though it is best done in a collet vs a three jaw chuck to ensure the ID and OD are concentric. Again, if you screw up on your sizing, it is not advisable to knurl guides in an attempt to make them “fit.” Worn out is worn out. Too large a hole is too large a hole. Any type of Band-Aids only shorten the life of your repairs. However, if you don’t truly understand what I’ve laid down in this paragraph, chances are you shouldn’t be trying to make your own guides either.
    Let’s start with guide removal. Before you do anything, make sure you take the time to clean the ports and make the guides clean, clean, and clean. Any carbon or broken off pieces can track mark your guide bore or even rip them oversize. For many old guides that have been in place for years or on sensitive alloy heads, it is a good idea to bore the old guides until they are within .010-.020 of the outside diameter. Then, it is time to heat your parts. Generally 250-300 F for cast iron, 300-350 for alloy does the trick. The very best way to remove a guide is to press it out vs beating it out. However, if you don’t have fixtures, this can be difficult.
    For most DIY, make sure you have a large drift which fits squarely on the end of the guide and the heaviest hammer you can swing with authority. Momentum is more important than weight here. We want the guide to push out smoothly in a few strategic blows vs getting whacked a million times. Guides come out the opposite of their shoulder. Some guides also use clips on the port side – double check for this. Here's two shots of it being done on a cast iron harley head:
    IMG_4399.JPG Notice that I media blasted the chamber and guide first . . that was to remove carbon.
    Once you have driven or pressed out the guide; stop to examine the guide bore. It MUST be free of deep gouges, scratches, or shiny/dull spots. It must be perfectly round. Top notch guide jobs include a honing of the guide bore on a sunnen or other rigid hone to ensure perfect heat transfer. Then, it’s time to fit guide to bore. For most cast iron parts a .001/.002 interference fit is good. For alloy, follow the manufacturer as each alloy is different. You may need to buy or make oversized guides and turn them to your exact needs. If you get lucky and your bores aren’t messed up – then standard guides will likely pop straight in. If you have cracks radiating from the valve guides . . .stop. Most cast iron heads can be repaired with silver solder (no, it won’t melt out), but alloys may need more specialized help. This work is for the specialist, not the DIY.
    When it comes time to install your new guides; it is not a bad idea to chill them. Overnight in the freezer or a few hours in a bag in the ice tray often does it nicely. Reheat your head/cylinder parts and get ready to move with authority. Again, the best way is to press or draw the guides in – but a good drift and a steady hand will do it well. Many like scotch lock – I use a dab of threebond under the shoulder to ward off any seepage down the guide bore. It shouldn’t happen, but shouldn’t has a weird way of appearing in vintage motorcycles.
    Here's one being inserted -- this fit was so good that I did not use any type of sealer under the shoulder. So far in 2500 miles the heads have shown no sign of either guide dripping.
    You can see reams for initial sizing in the above photo. I then take the guides and hone them to my final fits. I do like going for the middle range on factory specs. For most intakes this is around .0015-.002 (OHV) or .003-005 (flathead) and for exhausts .0025-.0035 (OHV) or .006-.008 on flatheads. I like to ream to within .0005 and then to finish on rigid hone whenever possible; brush hone for other times.
    Once everything cools down, it’s time to address the seat. Do not, do not, do not just “lap ‘em in” This is the totally wrong approach for a fresh guide. Yes, the motor will start and run – but it will not have good power when hot and the valve will not last but 50-60% of its normal service life. This is because it is nearly impossible to have the valve index to the same spot with a new guide. One of the most important things is for the seat to be fully concentric with the guide. Any more than about .002 concentricity and you will have hot spots on the valve face. This is compounded by lapping. When you lap, the moment the motor fires the valve creeps up/out the valve seat because of expansion. Because you only lapped it in one spot for room temperature . . . your gas seal is cruddy when the valve expands. Therefore, we cut or grind new seats to proper width and then fit the valves. You can lap if you like . . .but it’s more to see pattern than to seal.
    In the below pictures you can see the pilot for a neway cutter and the initial seat. This seat then has to be top and bottom cut for width and placement on the valve face. Improper placement also shortens the life of the valve.
    IMG_4410.JPG Note, the seat in the above picture is extra wide because I was cutting for an oversized head and dealing with multiple previous valve jobs. I often cut the 45 wide first. Some people start at 70/60 and work to 45 then 30/20/15. It all depends on how familiar you are with your equipment and how you were taught. All ways work and after a few dozen heads you get a pretty good feel for how much material you'll actually remove.
    The final step is to check your stem protrusion. On flatheads, we often can relieve for sunk valves and simply back off the adjusters; but on OHV, it often means new valve seats or other trickery
    Again, you sure can just knock out and knock in guides and lap the valves. The motor will run. Maybe not very well or for very long, but you’ll get back in the wind.
    The question is why you’d want to do so when for a very little bit more work, you can do it professionally and be done for decades.
    • 8231
    If I would ever use the insipid "like" button, it would be now, ChuckTheBeaterTruck!
    (My only immediate comment would be that "Seal-Lock Fluid-Weld" doesn't fall in the same category as all the other goober band-aids, as it is intended to alleviate the insulation issue with even a perfect press-fit.)
    Thanks for addressing this important procedure,..
      • 1669
      very nice write-up Steve, thanks for posting!
        • Jun 2018
        • 691
        Very happy to share. If we don't share this stuff . . . then the same crappy repairs come up over and over again -- blessed by the "internets" when folks go looking for someone to endorse their bad idea.
        Heck, since August 1 the following WTF!!! have wandered into my shop:
        1) A harley sportster where the owner just didn't check the oil for the last couple of thousand miles -- and didn't realize they had NO oil in the tank until it ran very, very hot the other day.
        2) A set of heads where the guide to stem fit was so out of whack the valves blued from keeper to head. How it didn't drop a valve is beyond me.
        3) A set of irreplaceable pistons where someone dug out the locks with a pick and ruined the lock bore
        4) A frame that had both the down tubes broken, the neck twisted, and the jiffy stand tab GONE. Owner didn't realize how bad it was until they removed the motor and the whole frame sprung to the side! The previous owner's "repair" was to bolt the motor into the frame and sit on the back bone -- then tack weld the broken pieces together. It was as DIY boogered as possible and so bad, I simply sourced a replacement frame.
        All of these things were caused by folks who have had motorbike licenses for many years and have owned or currently own a fair number of bikes. However, owning bikes and riding bikes ain't the same as having your head screwed on straight for dealing with vintage machinery repair.
        The oil one was just pure stupid by an owner who didn't repair the oil lamp when it burnt out and was too silly to check the oil level regularly. I still haven't told him the bill will be around $3500 -- mostly cause the bike is only worth about $2500.
        But the other three were due to amateur repair attempts gone wrong.
        Simply slowing down would have saved them a lot of trouble. But, then I wouldn't have any stories to tell.
        My old man was a big fan of fluid lock . . .can't say I have ever used it myself. No reason why . . .and I know plenty of professionals who do use it on all guide jobs.
          • 8231
          Don't forget seat installations, Chuck, (or Steve, forgive me!)
          There are even more advantages for a seat replacement, as it is a more difficult fix.
          Your customers remind me of decades past, and why I sent Sportsters down the road to T-Bone!
          (He is greatly missed, even if he always looked at me out of the corner of his eye.)
          • PaulCDF
            • Aug 2019
            • 1415
            Great article and pictures. I learned a lot. I Thank you.
            • kitabel
              • Sep 2018
              • 471
              Thanks.
              Heat is why for H-D 45 & UL the exhaust valve is heavier than the intake (different material - exhaust for intake: OK, intake for exhaust: no), takes looser clearance, and a wider seat.
              IIRC 45 guides .565", UL .595" OD.
              The Linkert Book
                • Jun 2018
                • 691
                Indeed . . .and I'm only part time! If I actually hung out a shingle I don't even want to know what garbage would cross my threshold. It's bad enough by word of mouth :-)
                  • 8231
                  I learned to say "no" in the Eighties, Steve!
                  Especially to relatives, anybody I went to high school with, and basically anybody too "local".
                  Back to topic,
                  When I got my Neway kit, I cobbled wooden fixtures to hold different heads so the pilots would always be straight up to the driver.
                  Then I found they were useful for pressing out the guides as well; I preferred to carefully drive most back in, as it quickly gave a feel for their fit.
                  PS: Anybody remember when in the Early Eighties the MOCO spec'd an enormous interference for their chubble replacement guides?
                  PPS: Sorry for another late edit, but if we want to discuss guide replacement, please let us discuss the cleaning prep prior to removal.
                  Every model is different (and if you apply the harley hammer to an indian the lesson isn't always easy.)
                  • BigLakeBob
                    • 2766
                    Great detailed write up, thanks. I do the same amount of press fit as mentioned and freeze the guide, but I only heat an aluminum head to 225*-250*. My experience with an higher temp is it seems to gull the aluminum sometimes, I also put a swipe of Lubriplate on the guide before installation, I feel it helps 'ease' the guide in without gulling. I also like to install using a punch as Cotten said to get a feel for the correct fit.
                    Bob Rice #6738
                      • 8231
                      It's all about feel, Bob!
                      Heating and chilling takes all of that away.
                      The first time a guide turned with the pilot, I stopped pokin' and hope'n.
                      (Please don't get me wrong, Folks; We aren't talking case races and stuff.)
                        • Jun 2018
                        • 691
                        It is funny what we all prefer.
                        On alloy, I learned to have a nice hot head doing vw and Porsche for my old man. We always went hot because the risk of cracks in those heads was very high. At a baked 300, with chilled guides, it was a slip fit for 3/4 of the guide and a single whack to seat. Rarely would reaming be necessary before the portahone.
                        I do guzzi heads the same way for other reasons, mostly the sectional thickness.
                        the commonality in all our approaches is zero guide bore buggering ;-)
                        And I'm pleased to learn I'm not alone. Sometimes I talk about these things and hear crickets chirp compared to the 50,000 likes a pic will get with a kid rolling sandpaper on a stick to "hone" a guide.
                        I cant for the life of me figure out why doing something the silly way is so popular when the proper tools and techniques are easily obtained.
                          • Jun 2018
                          • 691
                          Cotten, for cleaning prep, I prefer to media blast the ports very, very clean around guides. I won't remove dirty or carbon tracked guides. If they are horrible, I cut them off at port and then remove.
                          on flatties, I'm used to finding all sorts of port horror, poor relieving, and generally sunk seats resembling the Grand Canyon. And, yes, tons of hard carbon. I often chip after that before media blasting and then see how the ports actually line up to seats to figure out whether I can cut one more or am staring at seat replacement (ugh). Thank the gods for oversized valves.
                          on alloy, I soak heads in mineral spirits, then wire brush with brass. I have used glass beads, but honestly feel it takes as much time as a good bore brush. One thing I don't do is install seats in alloy heads. I don't have enough experience doing it in alloy and assume send it to those who do. I'm not a big fan of assuming all heads are the same and don't like being the guy who f'ed it up.
                          But, yep, I concur the whole thing needs to be clean and burr/carbon free before we start.
                          • gharper
                            • Nov 2009
                            • 527
                            Great write up! Can you continue and elaborate on the 3 angle valve seat? PLEASE!!
                              • 8231
                              I have four different blast cabinets, Steve!
                              Aluminum Oxide is most aggressive for hard carbon, and then beads make it prettier.
                              I have encountered Flatties where the guide is 'mushroomed' from the heat, and only whacking off the outside so the rest could be pressed into the port would do.
                              Damaged guide bores in aluminum heads must be dealt with individually; I really didn't like honing them unless there were no other options.
