VL main shaft
  • 34VLRay
    • Feb 2015
    • 26
    VL main shaft
    [ATTACH=CONFIG]27183
    Rebuilding early VL transmission, removed main shaft. Found the tapered end/clutch hub inner race cracked. Was able to remove this section ,l had never seen anything like this. Did HD make them this way or just a coincidence??
    • 2025
    Ray 1932 and down used a split bushing that was soldered to the recess in the mainshaft and then spun freely in high gear.
    Jerry
      All the Harley Big Twins through 1930 used a stepped mainshaft with the split bushings. Starting in 1931 the main drive gear had a larger hole through it, a bronze bushing was fitted inside, and an unstepped mainshaft was used. Those split bushings are a pain, as you need to solder them on, fill the joins, and surface finish to fit the main gear. Many JD and 1930 VL owners are now retrofitting their 3 speed gearboxes with the 1931 and up parts. The later main drive gears have become hard to find, so the 1925-30 main drive gears are being bored out, or the 1931 bushing thinned, to fit the later mainshaft. While we're there, the 1932-36 countershaft gear is also a better design than the early one. The early cluster gears use the short 2289-17 rollers, and the races are nearly always worn past the +0.0010" oversize rollers available. The later cluster gear uses the longer 2289-25 roller at one end and the 2306-32 rollers at the other end, also used for a long time on the small twin gearbox and readily available in oversizes.
      • 34VLRay
        • Feb 2015
        • 26
        Thanks for responding Steve. My question was the end of shaft from stepped area back towards taper this piece came off like it was a separate piece. The shaft itself looked like it was machined for a sleeve, were these shafts two pieces?
          Dear Ray, no the shafts are one piece. It looks like the bearing surface at the drive end was so bad that someone cut down the mainshaft and made a sleeve, a heroic repair I have not seen before.
          • 34VLRay
            • Feb 2015
            • 26
            The only thing I could think of is this might be a main shaft from Taiwan Ted. That’s typical of his products
