Truett & Osborn Crankshaft assembly
  • Steve Galli
    • Nov 2019
    • 93
    Hi All,
    Happy New Year!
    Thoughts on the quality and value of purchasing a set of these please...
    I am debating installing a set of these in my 58 FL... Not looking to stroke the old panhead... Looking for a smooth running engine...
    Thanks in advance all...
  • kitabel
    • Sep 2018
    • 471
    What's wrong with what you have?
    It would run smoother as an EL...
    The Linkert Book
    • Steve Galli
      • Nov 2019
      • 93
      Don't know yet... I will see once the motor is apart... Waiting for a shop to take the engine... Just researching my options... Thanks...
      • kitabel
        • Sep 2018
        • 471
        Things that would make me replace the OEM wheels:
        1. bad (egged, rust, keyway damage) tapers
        2. balance holes from prior (post-sale) job outside the wheels (very common)
        3. holes too close to the crankpin
        If I were replacing the wheels I would certainly increase the stroke.
        The Linkert Book
          I really liked setting up T&Os, Steve!
          They almost trued themselves.
          Don't look now, Kitabel,..
          But tapers can be corrected!
          http://virtualindian.org/10techfly.htm
          A greater problem with tapers were when they were pulled up so tight so many times that the wheels pinched the rods, and slopped between the mains.
          So I had JIMS custom-cut me longer crankpins; Still have plenty in stock if anybody needs one..
          • Steve Galli
            • Nov 2019
            • 93
            Thanks Cotten! We will see... really like the idea of a balanced assembly... I had a bad experience with a set of S&S Wheels so I am leery of using them again... Just want a dependable, stock, smooth running Pan that I can pamper...
            I want this to be the last time I have to open this engine again...
            • RichO
              • Dec 2001
              • 903
              I've seen 58 FL's but the person who answered you said to leave it an EL. O.K? I like T and O units. For the money their a spot on bargain and work well..
              DrSprocket
