oil oil oil...
  • hdhikaru
    • Feb 2010
    • 217
    oil oil oil...
    hi there,
    simple question about engine oil. mixing 50 +60 just to make 55 oil.... is bad idea? how about mixing revteck and genuine oil ... bad too?
    how often transmission should be changed?
    tks!
    Shin
  • Jcadams
    • Nov 2018
    • 45
    Do you put water in your whiskey ?
    • Steve Swan
      Possessed by Motorcycles
      • Aug 2013
      • 1589
      Dear "New Member,"
      Regardless anyone's level of knowledge who posts a question asking for help such as Shin, "answers" such as yours are not helpful and unnecessary. This purpose of this forum is based on a brotherhood committed to being helpful to others by sharing what they know and not displays of wit at other's expense. Imagine how you would like it if someone on this board responded as you did to Shin. I'm assuming you joined this board because you might need help if you have an old motorcycle you want to keep running. If you're here auditioning for approval of your comedic talent to other motorcycle people, you might want to join a DB such as AdvRider's to showcase your egotism. AdvRider is a very helpful DB that also enjoys your type of wit. As you are a "new member," your answer is not one that will be helpful to getting help from most people on this DB.
      Steve Swan
      27JD 11090 Restored
      27JD 13514 aka "Frank"
        Originally posted by hdhikaru View Post
        hi there,
        tks!
        Shin
        Shin!
        Mixing different weights of conventional oil does no harm.
        (I have no experience with Revtech oil, or mixing synthetic with conventional oil.)
        A fresh assembly should have its oil changed quickly to remove 'break-in' debris.
        First two rules of oil: Use clean oil, and lots of it.
        • Jcadams
          • Nov 2018
          • 45
          You are right Steve , my apologies to shin & everyone else. I will sometimes run 50 in my shovel if I ride it in December, in mass. By the way, but back to 60 in spring. I see no reason to manufacture my own weight oil. I have however added 50 to the 60 to top it off before a ride because that’s all I had on hand. Sorry again, thought I was being funny, but I am building a 69 flh now & do appreciate honest & serious replies.
          • hdhikaru
            • Feb 2010
            • 217
            thanks you all!!
            • FNG1
              • Oct 2014
              • 202
              Hi HD, different viscosities may be OK but not different brands. Different additives may not play well with others
              • ihrescue
                Super Moderator
                • Jun 2015
                • 1145
                Thanks Jcadams for your follow-up.
                Thanks Steve for your commitment to our forum!
                Mike Love
                AMCA Forum
                Moderator
                  I read somewhere, Folks,..
                  ..among the thousands of oil threads..
                  That some oils are not compatible with bronze bushings.
                  Anybody know of this for certain?
                    • 2044
                    I do like water in my whiskey.Tame it don't kill it !
                      • 4791
                      Sulphur based gear oils are not recommended with bronze bushings with a high sulpher content (as H-D used) as they can cause pitting and degrading of the bushing material. That is why H-D recommended motor oil in the gearbox.
                      • govmule84
                        Fat & Cranky
                        • Dec 2014
                        • 179
                        The way I understand this is the sulphur forms a sacrificial coating on metals. On steel, the coating comes off in EP situations. However, on yellow metals, the bond is stronger than the base metal, so the coating tears off and takes some of the yellow metal with it.
                        Not a chemist, but I think that's about the way it works. OT, but I found this interesting: https://www.widman.biz/uploads/Transaxle_oil.pdf
                          • 6041
                          Very interesting link, govmule84. Thanks for posting it.
                          • Paps
                            • Jun 2003
                            • 1814
                            Or sugar in your tea ?
                            • Paps
                              • Jun 2003
                              • 1814
                              The tune ! by Three Dog Night.
