Removing Protective Coating?
  • wideglide38
    • Jul 2008
    • 656
    Looking for suggestions how best to remove the protective coating from an old eagle iron gear. The string pull only split the coating and since this is an old coating it has a helluva grip. I tried an industrial heat gun, this help some. There has to be an easier way?
    William Edwards, AMCA #10035
  • vph-d
    • 1088
    Try dropping it into a coffee can full of Coleman fuel.
    VPH-D
    • wideglide38
      • Jul 2008
      • 656
      Thanks! It's swimming in Coleman fuel.
        If the stuff proves stubborn, William,..
        Coleman may be too clean and pure (and pricey).
        The best bang for the buck when it comes to digestivity is the pee out of the pumps.
        Combinations of fuel brands can be the aqua regia that eats even the best of rubbery compounds.
        • wideglide38
          • Jul 2008
          • 656
          Thanks Cotten...
          I picked off most of the "wax" off by hand before soaking in the Coleman fuel (almost 24 hrs.). After the soak, more rubbing with a cloth wet with fuel to remove the remaining residue. The gear came out fairly clean (and no damage to machined surfaces). Photos of cleaned gear with a light coat of spray oil.
          William
            .... The gear came out fairly clean (and no damage to machined surfaces)....
            You're right, William!
            P4gas might even eat machined surfaces eventually.
            Lately I've been using a walnut hull tumbler.
            (Wish I knew how to make a video, but instead imagine it at rotisserie speed.)
            • wideglide38
              • Jul 2008
              • 656
              Nice tumbler Cotten. Looks great for small parts.
              William
                William
                Thanks William,...
                The price was right.
                The support rod through the tank could easily mount a MDG, but honestly, I'd just run it through my hull blast cabinet down in the pit.
                Yet the tumbler might produce a better polish.
                And probably use less electricity.
