45 Magnum Engine
  • 45-Brian
    • Oct 2015
    • 32
    45 Magnum Engine
    Good 'Day All,
    I purchased a set of 45 cases that have been welded, machined and what I thought was ready to go to build a 45 magnum engine, however the cylinder bolt pattern do not match the early sportster cylinders I have. Below is a picture of the bolt hole pattern the was installed.
    Can anybody tell which bolt pattern I have?
    Disregard the actual gasket pictured as it was only used for illustration purposes, and measurments.
    Any help would be greatly appreciated,
    Thanks Brian
