Linkert bore grind marks?
    • 8223
    I hope I can ask a tech question here, Folks,..
    ...Without getting a schoolgirl rant like other forums.
    How many of you noticed grind marks in their Linkerts like the attachment?
    Anybody got a reason for them?
    Mine scares me.
    Thanks in advance,
  • BigLakeBob
    • 2762
    I have noticed them, I would just assume it was their quick way of deburring the hole.
    Bob Rice #6738
      Tom, I never understood why you see every Linkert carb as a Swiss watch. There not. It was a quick produced carburetor. After drilling it would go down the line like any other produced item. I'm willing to bet as it made it's way down the line after drilling there was a guy with a die grinder that hit every area with after-mass sticking out. He didn't give a rats ass what it looked like. His only job was to get rid of it. Bob L
        • 8223
        Maybe you don't give a rat's ass... But I take this seriously.
          • 8223
          Bob!
          Ain't that overkill for what a knife blade could scrape?
          That's a very crude assumption for an assembly that otherwise had incredibly accurate machining, such as producing the phenomenal idle bleed slots, which I still haven't an explanation any better than for the construction of the Egyptian Pyramids.
          L&L is just a generation past us, but so much has been lost forever.
            • 8223
            Here's another clue, Folks (attached),
            • BigLakeBob
              • 2762
              Bob!
              You know Tom, maybe I'm just not in a great mood today, but I sure don't get your attitude. You ask a question and then you say its a VERY crude assumption. What's your f'n answer then? Or will it be like last time when you ask how to fix something and then don't want to share how you did it. I machine every day and I wouldn't deburr like that, but I'm with Bob L on this one, a production part and the guy had to make time or be in the soup line. A knife blade on the front side of the hole is easy, back side not so much and time consuming, and 60% of the time the blade slips out of the hole and scratches the bore, then you would probably complain about that. Tom, I appreciate and learn from what you share but sometimes you come across pretty crude yourself.
              Bob Rice #6738
                • 8223
                Its like this Bob,
                I have enormous respect for the producers of the hardware that made our machines legendary.
                Our task as custodians of not only the hardware, but their legacy, is to study them beyond farting in the dark about them, declaring they were hacked out.
                If that's bad attitude, then I own it.
                My last post was a clue as to why I believe they did it. Ain't that "sharing"?
                • BigLakeBob
                  • 2762
                  As the bolts are drawn in it becomes round again, or if a warped face it won't draw and bind the plate.
                  Bob Rice #6738
                    • 8223
                    You are making the assumption, Bob,..
                    ..That the bore was created while torqued.
                    Tightening, or over-tightening, otherwise only distorts it further.
                    Was the crude de-burring merely because they were bored un-torqued?
                    Sad if it was....
