Trying to help my friend get some last minute details sorted on his Henderson Four which will be on the Cannonball. The valve guides lunched themselves, probably due to some massive springs being fitted.
He had his builder do new guides and valves and the job is great. But we need to get some more original springs. The heavy springs are still in place and we think they will be a problem.
Can anyone supply me with specifications on the original springs? Free length? Wire Diameter? OD seems to be 1" ID seems to be .800 or so. Free length, I think, is supposed to be about 2"? But that's just an educated guess. Number of coils? Anyone have a LBS per inch compression number? The ones that were in there were at a free length of 2.25" and tested out to about 60 LBS for 3/4". My gut tells me that's way too much for a nice low revving old MC engine.
I can source virtually anything for valve springs... but I need to know what to order. We have another Henderson nearby and are working on borrowing a sample (original) spring from that to test. But maybe someone here has some numbers or specs.
Thanks in advance!
Cheers,
Sirhr
Thanks in advance!
Cheers,
Sirhr
