Does anyone know the history and coding of late pan and shovel production numbers on a transmission. It is an overlooked item to know if you have an all original machine, but transmissions are replaced and future owners may not know the history of all the parts. Date codes on 1939 and up to early pans and 45's are easy to check.
What for example would the range be for a 1972 Shovelhead? I never gave it much thought when doing rebuilds, but restorations are different.
Might be a good question for Chris and others with detailed knowledge. Shelby
