Technique for restoring sand casting texture
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    In cleaning up these cases, there were some areas where the original casting finish was damaged, smoothed or deeply scratched. I also had to weld an area near one mount. As a result, the 'sand cast' finish had to be replicated/restored in these areas.
    Here is a technique for restoring the 'sand cast' finish.
    Take a piece of heavy grit (36 grit in this case) sand paper. Place sand down over the area to be restored. Then tap with a hammer while moving the paper around to expose new, sharp sand to the area to be blended. Only takes a couple of minutes.
    Here you can see an area mostly completed. You can see that it was a rectangular area about 1/2" x 1/4" that would have stood out like a sore thumb on the case.
    After the blending, polish with Scotchbrite, a bit of 0000 Steel wool and paste metal polish of your choice and it will be virtually invisible.
    Cheers,
    Sirhr
    • Feb 2003
    • 5353
    Thanks for posting this type of stuff Sirhr... Very informative!
    Cory Othen
    Membership#10953
