ULH Cylinder queation
  • Robert Luland
    • Sep 2007
    • 2075
    Boys I need some guidance here. This has to do with ULH cylinders. Are 74 and 80 cube cylinders the same with one being bored larger or are they different cylinders? I read Bruce’s paragraph on this subject but obviously I’m missing something. Thanks guys, Bob L
    AMCA #3149
  • Jerry Wieland
    • Jan 2006
    • 2017
    The 74 and 80 13 fin cylinders are the same casting. 80 cylinders were bored to 3 7/16 (vs 3 5/16") and relieved around the valves.
    Jerry
    • Robert Luland
      • Sep 2007
      • 2075
      Thanks Jerry but what do you mean relieved around the valve. I'm not retarted, just slow.
      AMCA #3149
      • Chris Haynes
        Curmudgeon
        • Jul 2002
        • 5950
        That means that several thousandths of metal around the valve is ground away to provide a better flow towards the bore.
        • Steve Slocombe
          • Jan 2003
          • 2178
          The 13 fin cylinders have 120-37 and 120-371 cast in the front/rear base flanges. They will be used on the 1937 Big Twin flatheads and the 1938-41 ULH models. The 11 fin cylinders have 120-38 and 120-381 cast in the front/rear base flanges, and were used on the 1938-48 74 cubic inch flatheads.
          • Jerry Wieland
            • Jan 2006
            • 2017
            Bob Cylinder on the left is ULH and the cylinder on the right is UL - both 13 fin.
            Jerry
