1926 J Pistons
  • 1926 J Pistons
    Can anyone help?
    I am trying to find out what the compression height is on a 61 Piston as I do
    not have one for reference.
    Hi JED......I have a 1928 61 inch piston. I assume what you mean be compression height is the distance from the center of the piston pin to the top of the piston. I measured mine and got ( 1 and 11/16 inch ) If you need a different measure, such as from the top of the pin to the top piston, let me know...Rod
      Hi Rod
      Thankyou for your reply, yes that is the measurement that I needed.
      Many Thanks Again
      Jed
