1920 WF Sport Twin Engine Pics
  • MMasa
    • 1192
    Originally posted by denismccarthy View Post
    Hey Mark
    Max ground the mains down to clean them up then made new custom mains and big end bearings. She's smooth! Check out those wrist pins bushings! Beauty!
    Oh and he had to re-heat treat the whole mess too. I've got his invoice at the museum. I'll tell you what all he did to it next week.
    Denis
    I'd be interested to know exactly what Max did to the crank. I have two sport cranks that will need similar work. I'd also like some contact info for him.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • denismccarthy
      • Jan 2012
      • 125
      Hey Mark
      I'll look at the invoice tonight. It was fairly extensive. I'll let you know this evening.
      See ya
      J.Denis McCarthy Come visit The Barber Vintage Motorsports Museum
      www.barbermuseum.org
      • Venus
        • May 2011
        • 27
        new plates
        Hi Louie,
        I have just rebuilt my engine and clutch with the new corks and this is indeed a lot of work.
        I do not know how it wil work because Ineed a few weeks to finish my bike and waiting for good weather to test drive.
        However I have made a DXF or computer drawing of the clutchplates.
        I can send you the file so you can upload the shape into a cutting machine to have some plates cut.
        Peter
        • MartinK
          • Jan 2012
          • 31
          sport clutch discs
          Originally posted by LouieMCman View Post
          I've owned a Sport Model for about 16 years. When I got it I pulled the motor and removed the cylinders and found the bottom end good and tight so I only honed the cylinders and relapped the valves and have been riding it ever since with stock bore pistons and rings. It had about three sheets of newspaper for had gaskets, you could still read the words on the paper.
          One problem that all Sport owners seem to have is with the clutch, I have been meaning to redesign the plates by having most of them bonded with material and therefore getting rid of them damn 132 discs. I was just wondering if you have given any thought to the clutch yet? I would be interested in some new discs if you are going to get some made up. Thanks.
          Hello Louie,
          Maybe the clutch problem is solved, if not here could be one solution.
          When I recently disassembled my engine I noted that my father had replaced (in the 1970ies)the clutch discs with custom made discs, made from Surflex wet clutch discs. They have worked very well. I am researching to try and see if I can find some more/new discs to do new ones by laser or watercutting the correct profile.
          follow my restoration on http://flattwinsport.wordpress.com
            Hey Chris
            Were did you find that picture? I've never seen it before. We do tons of research before we dig into a restoration, but I've never seen that pic?? Thats a really good one!
            It was purchased from Pohlman Studios when the H-D photo archives were there.
              • Aug 2001
              • 1343
              Martin,
              I would love to have some of those discs, if you can find or make some let me know, I'm definitely interested in buying some, thanks.
              Louie
              YouTube >>> LouieMCman
              • MartinK
                • Jan 2012
                • 31
                Originally posted by Venus View Post
                Hi Louie,
                Peter
                Venus,
                Could you please send me a copy of the DXF drawing on the clutch discs if it includes the discs' outer profile as well?
                I wil ltry to have some new friction plates done and it would save alot of work to have it drawn up.
                regards
                Martin
                  • Aug 2001
                  • 1343
                  Hi Louie,
                  Peter
                  Hi Peter, yes I would very much like to have the file for the plates, thanks.
                  Louie
                  • MartinK
                    • Jan 2012
                    • 31
                    Good news..
                    I have been struggling to find the clutch discs that was modified and used on my sport. Just when I was about to give up I found the correct dimensioned Discs to modify!
                    I will have them water cut the outer profile and inner diameter from my dxf drawings. The friction discs are Italian made.
                    I thought I'd do a small batch and I would like to know if there is any interest from other sport owners, Louie, Denis?
                    I will only charge the real cost, beeing in sweden, it might be a little high though.. The modified discs could run about 25-35$ each+shipping.
                      • Aug 2001
                      • 1343
                      Martin, I bought some cork material and punched out 132 disc and installed them about a month ago. After riding and adjusting the clutch a few times it is better but the jury is still out whether it will hold up for long. I was searching eBay for clutch discs and found some for British bikes that might work after modifying. Can you tell us what plates you are starting with? Thanks.
                      Louie
                        • Aug 2001
                        • 1343
                        some pics.......
                        Louie
                        • MartinK
                          • Jan 2012
                          • 31
                          #27
                          Hello Louie,
                          Ok I see, good job
                          I will make them from Sachs clutch discs from the brand Surflex. There are also alot of budget chinese made Sachs discs, but I thought I'll go with the Italian.
                          Cheers
                          Martin
                          • MMasa
                            • 1192
                            #28
                            Martin
                            What is the part number?
                            Mark Masa
                            Mark Masa
                            www.linkcycles.com
                              • Aug 2001
                              • 1343
                              #29
                              Martin,
                              I found this Surflex 5 disk set part number S1147/B, but can't verify it's correct, is this what your starting with? Thanks.
                              Louie
                              • MartinK
                                • Jan 2012
                                • 31
                                #30
                                Hello,
                                Sorry for the late reply. I just received the discs from the shop, but there was a minsunderstanding, the discs were "surflex" type and not the ones made by surflex..
                                I will try to reach Surflex again, they are very difficult to reach and I will have an Italian friend to help me. Maybe then I could get a correct partnumer and order directly from them.
                                Sorry.
                                Regards
                                Martin
