26 JD trans spacer
  • 58pan
    • Apr 2011
    • 16
    26 JD trans spacer
    Is there a spacer between the sprocket nut and the clutch hub. I'm try'in to help a friend out and I'm not sure but it seems that there should be one.
  • sswaney
    • 302
    Yes. It is a large diameter washer/spacer. It is used to set up the clutch housing end play. It is about the diameter of the thrust surface on the back of the clutch housing and is a close fit on the main shaft.
    • indianut
      • Feb 2005
      • 308
      What should the End Play be on the Clutch Basket? Thanks.
      http://laughingindian.com/
      A.M.C.A. Member Since 1986
        • 2176
        Harley looks for about 0.005" end play on the clutch basket. This is set by using varying thicknesses of the 2500-19 hardened thrust washer that goes under the clutch roller bearing. In practice I reckon it's less critical. In particular, too thick a washer binds up the clutch. Gearbox mainshaft end float is set separately by screwing in the ball bearing holder on the kicker side of the gearbox. Again 0.005" seems a good number, and I start by tightening the ball bearing holder until the box locks up, then taking it out about one third turn to get it free running. The spacer collar 2239-25 you asked about earlier goes under the countershaft sprocket and around the stub shaft of the main drive gear.
        • 58pan
          • Apr 2011
          • 16
          Thanks I'll let my friend know.
          • 58pan
            • Apr 2011
            • 16
            told my friend that and he would like to know where he can get the right parts to make the 1926 go
            • 58pan
              • Apr 2011
              • 16
              where can I find these parts you can let me know my friend won't use the the www
                • 2176
                Dear 58pan, your friend is going to struggle in the 21st century if he won't use the Internet but let's try to help him out. I prefer to do business separately from technical discussions on this bulletin board, and my contact details are in the Club magazine. I have all the parts mentioned so far. Best regards.
