hydraulic or soilds for 62 pan
  • sailfish
    • Sep 2010
    • 175
    i have torn down my pan to the frame so while the moter is out i was going to put the hydraulic lifters and push rods in and take the solid lifters and push rods .Should i go back to the stock lifters and push rods or just leave the solids
  • indianut
    • Feb 2005
    • 308
    You should go back to Stock.
    http://laughingindian.com/
    A.M.C.A. Member Since 1986
      Sailfish!
      Are you certain that you have a stock cam?
      You may want to put a dial indicator upon a tappet and measure the lift.
      Many common replacement cams are not compatible with hydraulics.
        • 2044
        Are the bores of the lifter blocks too worn for hydraulics? oversize lifters might be necessary. That is why many went to solids
        • portagepan
          • Feb 2006
          • 580
          I like the hydraulics in my '65. I used oversized Siftons, and they work good. Stock cam. Mike
          • cdndewey
            • Jan 2005
            • 438
            I had solids on my 62 when I first got it. It took me about a year to come to my senses and put hydraulics back in.
