45 shift fork shaft
  • kg993
    • 263
    45 shift fork shaft
    Does anyone have a 41-up shift fork shaft handy to measure? I got the rest figured out but the fork shaft that came with the transmission parts is too short for the case. It measures 4.735" overall.
    Kerry
    Kerry AMCA # 15911
    • 2044
    it's just over 5" the one you have is '38-'40
    • kg993
      • 263
      Thanks, that is good to know. Since the case has been welded on I was concerned it had been altered.
      And thanks for the reply on the manuel and spacing also.
      Kerry
      Kerry AMCA # 15911
