Phillips or slot
  • kg993
    • 263
    Phillips or slot
    I've searched till I can't search no more. Does the 58 FL trans top use phillips or slot screws? All I find is countersunk screws. Also when did the screw head diameter change (I know the 58 uses the small head screws)? And while I'm asking when did the trans mount plate get the threaded ft. holes?
    Thanks, Kerry
    Kerry AMCA # 15911
  • len dowe
    • Oct 2002
    • 520
    1952 was the yr they started to change over from slot to phillips. you could go both ways. 58 takes phillips.
    AMCA #765
    • kg993
      • 263
      Thanks, I looked under special notes for 52 after you posted that. Now I need to find a set of slot screws for the 51 and the R-3 speed that both have phillips. One good thing is there will be pleanty to pick from for the 58.
      Thanks, Kerry
      Kerry AMCA # 15911
