Weston Ammeter threads
  • DanM
    • May 2005
    • 465
    Does anyone know the specifics of the threads on the mounting studs of Weston Ammeters? They seem to be 38 or 40 tpi? The tips of mine have been buggered, and I'm trying to think of a way to restore them? And where are the nuts available?
    Thanks! Dan
    Dan Margolien
    Www.yankeechapter.org
    Pocketvalve@gmail.com
    • 6018
    Dan, the Weston ammeter I have has 10-32 studs, which is a standard thread. Your's may be different. Do you have a thread guage ? When you find out for sure, (and if it is an odd-ball thread) you can go to MSC industrial supply and get a special thread die to chase the treads. You may also want to get a matching tap so you can run it through an appropriate size nut.
    • DanM
      • May 2005
      • 465
      THX Eric. I did use a thread gage- the threads seem so fine, I was hoping it is -32, but will check again. I also considered opening up the gage and seeing how the stud is secured, and simply replacing it with a new piece-
      THX
      Dan Margolien
      • Perry Ruiter
        Henderson KJ wanted!
        • 621
        Thanks! Dan
        The early Super X parts book lists the thread as 3/16-40. If anyone has a source for a tap and die in that size I'm interested. The closest I've been able to find is 10-40 ... Perry
        • DanM
          • May 2005
          • 465
          I remeasured, and agree with Perry. OD of stud is right at .185 and the threads are -40. I found the tap and die at www.minicastings.com, $5.70 and $11.88 respectively.
          Dan Margolien
            • 6018
            That's a good price for a tap and die. You'll probably never use them again but if they save your guage, it's money well spent.
            • DanM
              • May 2005
              • 465
              I have accumulated quite a few taps and dies with 1 use on them. I'm doing a JD, and the exhaust valve cover threads on the lifter block were damaged. I actually bought a crazy die on ebay and managed to rethread the 2 blocks!
              Dan Margolien
              • bobbyt
                • Mar 2008
                • 98
                I believe the nuts are 10 x 40
                Bob Turek
                $769
                • Perry Ruiter
                  • 621
                  Let us know how those work out. I had found some 3/16-40 ME taps/dies but passed as I was worried ME was some nutbar British thread, that, while close isn't quite close enough with the proper thread form ... Perry
                  • bselph
                    • Jun 2009
                    • 311
                    Thanks! Dan
                    Check with Kevin at Indian Guage Co.
                    Bob Selph
                    1933VC/1934LT Sidecar
                    1940 Sport Scout
                    AMCA#15215
                    • DanM
                      • May 2005
                      • 465
                      Well, you are right. The supplier said "ME Model Engineering (British Straight Thread"
                      I ordered anyhow. Will report back.
                      Dan Margolien
                      • DanM
                        • May 2005
                        • 465
                        I received the tap and die. I rethreaded brass nuts with the tap. I ran ther die carefully over the old stud, about 1/3 -1/2 way down. The nuts run down fine with decent engagement.
                        Only the very tip of the stud that was most stripped doesn't really hold the nut because so much metal was gone from the original stripping.
                        So, I'd say mission accomplished!
                        Dan Margolien
                        • awander
                          • Nov 2001
                          • 54
                          M.E. Thread is a 55 degree thread-similar to the Whitworth, and British Standard threads. For a low-stress application like an ammeter, I would think you could mix'-n'match 60-degree and 55-degree threads and never know the difference.
                          Andy Wander
