Ignition Coils
  • vph-d
    • 1088
    Ignition Coils
    Does anyone know of a way to test old H-D square coils with an ohmeter? I have several -48 style coils I'd like check before installing them.
    Thanks, VPH-D
  • BONES47FL
    • Apr 2009
    • 73
    Though it is not with an ohmeter, there is a bench test for coils in Palmer's book on page 400...Bones
    • vph-d
      • 1088
      Anyone? Anyone?
      VPH-D
        • 5953
        If ya can find a Duo Gap tester that is what the MoCo used.
        • Perry Ruiter
          Henderson KJ wanted!
          • 621
          That's a really cool picture Chris. You can see a Weidenhoff generator test bench off to the right.
          Thanks, VPH-D
          Anyone? Anyone?
          VPH-D
          Attached is an internal coil wiring diagram (courtesy of Uncle Frank). You can see the two external terminals are the primary winding and the two plug wires are secondary. I don't have a coil here to take readings off of, but the primary should have low resistance (< 10 ohms) and the secondary should have high resistance (> 10,000 ohms) and there should be no reading between primary and secondary. I think a coil can still be bad if it passes those readings, but it won't be good if it doesn't ... Perry
            • 5953
            [QUOTE=Perry Ruiter;103729]That's a really cool picture Chris. You can see a Weidenhoff generator test bench off to the right.
            The Duo Gap tester is also a Weidenhoff product. H-D used a lot of Weidenhoff stuff. Weidenhoff today is known as Sun.
            • Johnny
              • Jul 2003
              • 109
              The values I usually read for the primary side of the coil are around 1.2 Ohms and for the secondary side are around 17,000 Ohms.
              An infinite reading on either side would indicate an open circuit and values a lot lower would indicate some of the turns are shorted. Any reading within maybe 20% would indicate your coil is good.
              • Perry Ruiter
                • 621
                And if I understand the corporate hierarchy properly, Sun is owned by Snap-On ... Perry
                  An ohms meter is just giving you nothing more than a quazy continuity test. Is there a way to load test it?
                  • bmh
                    • Feb 2007
                    • 901
                    Energize and trigger it with the leads held off ground, should see a strong spark. They can still go thermally intermittent, but that's the best way I can think of to test them. If you have a running bike just disconnect the coil that's on it and use some jump leads to the coil you need to test but all you really need is a good battery, some wire, contact points and condenser. I've seen many 12 volt coils pass the ohm tests and still not run right.
                    Brian Howard AMCA#5866
                    • camsaure
                      • Nov 2009
                      • 135
                      Hi, Has anyone got a copy of the instructions for the Wiedenhoff Duo Gap model 358? I just acquired one of these in very good condition. I can probably figure out how to use it, but I am sure there are some other tricks that I am not aware of. Thanks, Cam
                      • kenny
                        • Nov 2019
                        • 19
                        Have you found information about model 358 duo gap tester I have a tester that needs restoring but no operating instructions. Any help greatly appreciated.
