What regulator is used when 32E 3 brush converted to a 2 brush ?
  • TimR
    • Sep 2009
    • 74
    As it is a well known fact that the 32E 3 brush generator was not designed to maintain the battery charge if your "State Laws" require that you ride with the headlamp on all the time and/or your cruising in the 50 mph+ for extended rides. One option would be to convert the 32E 3 brush to a 2 brush generator and control output with a voltage regulator. While searching the web for a suitable regulator, I saw http://v-tronic.com/vtronic/index.ph...d=42&Itemid=55 Does anyone know of a supplier that markets these? Anyone have experience with this regulator or other ones that you might want to comment on, positive and negative feed is welcomed. Thanks Tim
  • Perry Ruiter
    Henderson KJ wanted!
    • 621
    I've used their 12 volt regulator on 32Es I've converted to 12 volts numerous times with no problems. I've never used a 6 volt one but I would expect it regulator to work equally as well. Just recently I asked Kurt at 45partsdepot to bring in a couple 6 volt units for me to try. You may want to contact him and ask about one for yourself ... Perry
