headlight stamping restoration
  • rustynuts
    • Feb 2009
    • 43
    is there anyone who can re-etch (restore) worn out headlamp stampings.
    • 5950
    Check with jewelry repair shops and ask for the name of a good engraver.
    • Glenn
      Member to Remember
      • May 2007
      • 403
      i sent my headlight to be re stored and chromed and re etched to Paul's Plating and it came out fantastic
      SATSET138 adalah product kualitas premium yang menjadi rekomendasi dan terpercaya terbesar di ASIA.
      Moose
      aka Glenn
      • 46CHF
        • Nov 2009
        • 68
        beware
        While I truely believe Pauls Chrome is the best out there, a word of warning. I sent a pristine motolamp bucket for chrome and they ground off the rivits for the mounting bracket and gave it back to me in 2 peices with screws to reassemble it with, the screws have smaller head diameters than the original rivits and instead of drilling out rivits they used a grinder and scuffed up the bracket inside the bucket. Had they told me they were going to molest my vintage original bucket i would have opted for paint. So still looking for another motolamp bucket,lessen learned. The chrome and engraving was top notch though!
          While passing over this subject. Does anybody here know of someone that can reinstall the rivets in guide headlights and signal lights? Bob L
          • micmac
            • Feb 2009
            • 466
            also on this subject, who does re-silvering? I believe that is the name of the process to replenish the reflector.
            Pete Cole AMCA #14441
            1947 Indian Chief
            • Rollo
              • Nov 2008
              • 599
              head light resilvering
              One of my buddies here just had one redone for a 48 pan and I am getting ready to give him ( Stephen Polosky) two more for me at Metro Plating and Polishing 4110 Howard Av. Kensington MD. 20895 301-493-4009 or 800-938-5811. He is experienced with these and work looks first rate. Price was $75. Other AMCA guys in the area use him as well.
              Tom Hardy (Rollo)
              AMCA #12766
              • micmac
                • Feb 2009
                • 466
                Thanks Rollo, heck I was in Westminster, Md Thursday.
                1947 Indian Chief
                • rustynuts
                  • Feb 2009
                  • 43
                  stamping refurbished
                  stipped, cleaned and polished the bucket- detailed the engraving with a dental pick- etch primed with phosphoric acid and dipped in enamel. looks great!
                    • 5950
                    Colony make rivet replacement kits for both headlamps and spotlamps. They are bolts with a rivet head on them. Just bolt them together and nobody is the wiser.
                    • GrandpasHarley
                      • Mar 2008
                      • 25
                      Brass Headlamp
                      Was this a brass headlamp.. or a later steel one?
                      Josh Richardson
                      1948 EL Panhead
                      www.GrandpasHarley.com
                        • 5950
                        I have always found the brass headlamps were chromed and steel were painted.
                          • 8231
                          I found a O.D. Cycle-Ray in a parking field the day after a local auction. Some tractor fellow must have decided it wasn't important.
                          There was some rust pitting in the worst place: the point of the bucket where the stamp is, and nearly obliterated it.
                          I had no problem smearing some spot filler into the pits and stamp, and then removing it from just the stamp with a toothpick, before it hardened. After repeating the procedure a few times, the lettering became quite distinct, and took paint well enough for my rat.
                          I'm certain that any one of you could do better, but I hate to paint with anything but a brush.
