Best Spark Plug for a 1937 UL
  • Wade
    • Apr 2009
    • 13
    While I'm getting new spark plugs for my 1937 UL HD I thought I would see first if anyone here has a favorite that would fit that engine?
    I love a kick start, but I'm not fond of having to crank it over and over while a crowd gathers out of curiosity and inevitably for amusement. If you have a suggestion for a favorite spark plug that would work for a 1937 UL I would sure like to hear it.
    Thanks for any opinions/insight.
    - Wade
  • RichO
    • Dec 2001
    • 903
    plugs
    Either original air cooled HD #3's or the suitable sub, champion D-16's. They're 18 mm and fit Super X, 101 Scout's, and Knuckles and flatties.
    DrSprocket
    • Rollo
      • Nov 2008
      • 599
      plugs for 37UL
      I have been using Champion D-16 or D-14 plugs for over 30 years in my knuckles and flatty's and no problems. I have original #2 and #3 plugs but try to save them since they are so expensive now. I have VL's from 33-36 and knuckles from 41-47 and they work fine and you can get them at most auto supply shops or tractor supply shops.
      Rollo
      AMCA #12766
      • rousseau
        hillbilly member
        • Jul 2003
        • 261
        NGK A-6
        Got mine from "Bullwinkles cycle" (502) 223-7688
          • 2017
          C-86 AC or 386 Autolite at the parts house. Refuse to run Champion in anything but thats another story.
          Jerry
          • Wade
            • Apr 2009
            • 13
            Thanks for the help! - Wade
            • ronald
              • 33
              check out your local NAPA store for the D-14 or D-16 Champs. I've been using them for a number of years. At $2.29 ea in a box of 6 they won't tear up your wallet.
              Ron
              • joel58pan
                • Nov 2009
                • 15
                Are the Champion D-14 and D-16 the same heat range as the H-D #2 and #3, respectively? What heat range (plug) would a 45ci with #5 heads want for a plug?
                  • 8231
                  Folks,
                  Beware that modern productions of NGK A-6 plugs are resistors, and will foul with conventional ignitions.
                  (NGK's tech support denied it, but my vendor discovered that they were made to accommodate modern Wisconsin motors.)
                  A simple test with a common ohmmeter will detect the modern from NOS.
                  Older plugs have a knurl, and a thicker hex as well.
